Thanks Spiros and seem pretty sturdy as well.
Thanks John, at this point getting closer to wrapping this long term build up.
George, these chrome pens really are the ticket over the standard Chrome Silver I was using for years on the oleos.
Before installing the wheels. First to attach the lower antenna just forward of the nose gear bay.
Next is the assemble the spinners and simply snap them in place in front of the nacelles. Rather simple process from Hasegawa. No poly caps or rings to hold them in place.
1. The spinners just snap in place over these stubs in front of the nacelles
The Lightning up on her gear ready for those wheels.
The Aluminum hubs are masked off and Tamiya Tire black is air brushed over the tires.
Then removed from the sprue and the area trimmed are painter Tire Black.
The masks removed from the nose wheel.
The nose wheel is removed from the sprue and then attached to the nose gear strut.
The main wheels are assembled.
Then both main wheels are then attached to the main gear struts.
The wheels went on very well. They should last for years sitting on the shelf and some movement.
Once the wheels were set, Put all three on the ground and sits at the proper nose up attitude. The spinners in place, the left one is a bit loose.
Finally removed the masks on the flip up access door.
next up the dreaded gear doors...
More to follow.
