Welcome to week three of the AV-8B Plus project. During this past week I worked on all the under wing stores. Starting with the AIM-9 missiles, I opted to use the Meng version. The Meng ones are much more accurate looking and also have more accurate decals. The client wants to also add 500lbs JDAM’s so I am using Eduard’s resin version. Once these were assembled and painted I then assembled to drop tanks. I then finished the under wing store by building and detailing the Litening targeting pod. The kit supplies decals for the rear screens. After applying the decals I was not happy with their appearance. I dug thru my extra photo etch bins and found two screens that matched what the actual pod looks like.
With all the under wing stores completed I built up and detailed the main landing gear. I they painted the first two colors of the scheme. The lower sections were painted FS36375 Light Ghost grey. The upper sections were painted 36320 Dark Ghost Grey. Later I will paint the top sections with FS35237 Medium Grey to complete the tri-color scheme.
Finishing off the week I scratch built the HUD. The kit version was a bulky hunk of clear styrene. I used some spare photo etch sides for the mount and thin styrene for the base. I added a drop of acrylic gel to replicate the HUD lens and clear acetate for the HUD glass. Moving forward I detailed the wing gear and getting ready to modify them. On my previous build of this same kit the wing gear was slightly longer and required modification so the aircraft will rest on all 5 wheels. Once I have the landing gear modified and installed I will begin adding all the decals.
All the details and photos are in the build log at: https://davidsscalemodels.com/build-log/av-8b-harrier-plus-vma-214/
