ICM B-26B Maruader
Started by David Odenwald · 25 · 2 weeks ago · . 1/48, B-26B, ICM, marauder
    David Odenwald said 10 months, 3 weeks ago:
    Since I now have my greedy mittens on the kit I figured I should create a WIP entry for the menacingly beautiful Marauder. But for right now this will be low priority as I bring other projects to the finish line. But stay tune as my interests just may short circuit these well laid plans.
    Chuck @uscusn, Spiro @fiveten, John @johnb, Clint @curtisshawk, Tony Prince @tony-prince, Tom @tcinla, Louis @lgardner.
    Spiros Pendedekas said 10 months, 3 weeks ago:
    Looking forward to it, my friend @kahu!
    First things first decided to investigate the cowlings since that is one of the bigger fit issues with the Monogram kit.
    They fit very well. The cowlings are identical. With the carburetor intakes found a subtle pitfall that the ever vigilant attention to detail and reading the instructions model builder should not trip over.
    The intakes can be swapped and still fit. The cowling on the right has them incorrectly fitted. Those little vents should be on the outer side of each intake.
    John vd Biggelaar said 10 months, 3 weeks ago:
    Looking forward to seeing you progressing on this one, David @kahu
    Great research on the cowlings, my friend @kahu!
    Chuck A. Villanueva said 10 months, 3 weeks ago:
    Yes one can easily not pay attention mixing up the cowling parts. Good tip. Already found that the horizontal stab will not have the same problem that is a big issue to address on the Monogram kit. Will be watching closely as you progress.
    David Odenwald said 10 months, 2 weeks ago:
    Added some tabs to help with alignment since ICM did not provide a lip for the parts.
    Once the intakes are glued on; one, then the other making sure everything is snug with no gaps then glued the top seam between intakes while squeezing the cowling closed.
    The result looks infinitely better than I have seen others post about the Monogram cowlings.
    Great idea to install those alignment tabs,David @kahu
    Nice aids, my friend @kahu!
    Pedro L. Rocha said 10 months, 2 weeks ago:
    I’m following your work here too if you don’t mind David @kahu
    Curious to see how this new kit goes and just how much we can make out of it
    David Odenwald said 2 months ago:
    Marauder maybe moving up in build queue just because I feel the need to fix this massive goof ICM perpetuated.
    What goof is this? The baffles for the waist guns that ICM molded. Basically going to shave a lot of plastic off just to start the fix.
    Spiros Pendedekas said 2 months ago:
    Indeed, it looks different than in reality, my friend @kahu!
    John vd Biggelaar said 2 months ago:
    Good decision to modify it to match reality, David @kahu
    Michael Turner said 2 months ago:
    G’day David (@kahu),
    This photo shows what ICM have represented for the airstream deflectors.
    https://www.alamy.com/utah-beach-manche-department-cotentin-normandy-region-france-image439032701.html?imageid=D96FDA7B-F798-4088-8A3D-CBD9C26A1C2D&p=409650&pn=1&searchId=df403b6499f24cd45c1f9bfd25643791&searchtype=0
    I think that is a later model (F or G?).
    My quick google search seems to indicate that these deflectors were sometimes added at the frontline, so perhaps you should check the aircraft you are modelling.
    I’m looking forward to further progress.
    Michael
    The green fuselage is the Monogram kit and you can kinda see they got the deflectors correct. What ICM molded looks more like crenelations atop battlements.
