Hi, Stephen (@stephen-w-towle): Tamiya Clear is pretty thick as it comes from the bottle, so I thin it using Tamiya Lacquer Thinner or Tamiya X20. I like to thin it 50-60%, and then I spray it using about 15 psi. Anything higher and you risk flooding the surface. I spray at least 2 thin layers, waiting about 30 minutes between the applications. Natural metal finish is really good for showing surface problems, so I treat it like I am working on a canopy. I use 4 increasingly fine grits, and then I polish the surface with a soft cloth, like a t-shirt. I have only done 3 or 4 NMFs, so you probably don't want to take my word for any of this. I do a lot of reading and that's where I get most of my ideas. By the way, I found a sanding stick that really works well for this. It has 4 grits on one stick, from medium to very fine. I get these at Sally's Beauty Supply for just a couple of bucks each. They are my go-to place for a lot of hobby stuff, like sanding sticks, spray bottles, and several other handy things for model-building. My other hobby is model railroads, and one of the sites I use has several videos covering the stuff you can get at Sally's that can be used in hobbies. We have all finished the 104 and we plan to post them together, probably early next week. I plan to take a week off from models to finish cleaning and arranging my hobby room. Thanks for following along on the build.
1. This is the one I get at Sally's that I use on NMF. Two or three dollars at Sally's or $7 on Amazon.
