Lockheed F-104 Starfighter: A Triple (Plus) Build
Started by George R Blair Jr · 113 · 6 hours ago · F-104, F-104G, Lockheed, Starfighter, Triple Build
    Carl Smoot said 1 week, 1 day ago:
    Looking at that Green paint on the Starfighter has got me rethinking my Kinetic in natural metal. Maybe I should just buy a second one and have both! 🙂
    Looks great so far Spiros (@fiveten)
    Spiros Pendedekas said 1 week, 1 day ago:
    Thanks my friend @clipper!
    Will be finished in Vietnam camo, the pattern will be identical to this one...
    John vd Biggelaar said 1 week ago:
    That's a nice scheme, Spiros @fiveten
    Will look amazing when finished.
    Wishing you a very nice holiday.
    Working on a small upgrade of the C-2 seat. I will be adding a black/yellow marked handle, not sure what the correct naming is, and some mask tape seat belts which I painted linen.
    Spiros Pendedekas said 1 week ago:
    Cockpit looks great so far, my friend @johnb!
    @fiveten, thank you, Spiros. Trying to get the fuselage closed this evening.
    John vd Biggelaar said 6 days, 17 hours ago:
    With the seatbelts and the ejection handle added it was time to close up the fuselage.
    Fitting was not entirely perfect so I aligned the upper side as good as possible. The bottom side definitely needs some attention.
    Also the tail section is attached now, just a few points to clean up.
    George R Blair Jr said 6 days, 14 hours ago:
    Looks great, John (@johnb). They all look remarkably similar at this stage. I need to get the tail on mine.
    John vd Biggelaar said 6 days, 12 hours ago:
    @gblair, thank you, George. Before attaching the wings I first want to clean up the seams.
    Felix said 6 days, 11 hours ago:
    John @johnb, those seatbelts look really nice!
    George R Blair Jr said 6 days, 8 hours ago:
    That is my plan also, John (@johnb). It is a lot easier to smooth out the fuselage seams if you don't have to work around the wings. I am hoping to get the hobby room arranged enough to start work on the F-104 again.
    John vd Biggelaar said 6 days, 8 hours ago:
    @fxrob, thank you, Felix
    @gblair, a well arranged hobby room is something which makes it easier to find your tools. Looking forward to how it looks once all is in place.
    I'm pretty sure that those sink marks are not present on the real plane.
    Spiros Pendedekas said 6 days, 8 hours ago:
    Excellent job so far, my friend @johnb! I also had some sink marks at the same places and had to fill them.
    John vd Biggelaar said 5 days, 21 hours ago:
    @fiveten, thank you, Spiros. Those marks are usually not that easy to remove. How did you achieve that?
    Currently I'm trying to use plastic putty for that.
