Messerschmitt Bf 109 Werke
Started by Erik Gjørup · 305 · 10 months ago · 1/48, 109, 109 werke, airbum, Bf109, Haldværk, halfworks, Messerschmitt, quarterscale
    Nice prep work, my friend @airbum!
    Well, idle time in the tower needed to be filled in Spiros @fiveten 🙂
    Better starting correctly instead of having to do corrections in the end, Erik.
    John @johnb, whatever you can do before comitting to the build will actually save time when embarking on the build - right?
    more Emil stuff
    While I was rolling, I did some more work on one of the Emils in the stash
    This is such a nice little kit, low priced, easy to build, and loads of AM details out there. What’s not to like? Do add a few to your stash, it can be built as a nice 109 OOB, or fill it with AM or scratchbuilt parts, your choice.
    I decided to thin the exhaust shields
    Looks better that way
    And then I started to open up the vents in the fuselage
    Having chaindrilled with a thin drill, some knifework will follow later today
    The cowling did get a bit more done, here you have one with and one without the thinning
    It will be just that tiny bit nicer after assembly and paint – for those that will notice it that is. Sort of extra detailing without a lot of effort and at zero cost!
    Do stay tuned to check up on the next 109 bits and pieces here at HalfWorks
    Love all those small field improvemants, my friend @airbum!
    @airbum,
    "whatever you can do before comitting to the build will actually save time when embarking on the build – right?"
    Fully agree Erik.
    Great 'tiny' looking details.
    Pedro L. Rocha said 3 years, 8 months ago:
    Nice drilling Erik! I still think Tamyia Emil is the best in the 48 scale, let’s see what the market brings around soon, perhaps I’ll have to change my opinion
    Louis Gardner said 3 years, 8 months ago:
    Erik, @airbum
    Have you ever thought about changing professions and doing dental work or oil field work on the side ? 😉
    You have the drilling part down to a science... I have a question for you... What size drill bit are you using for this work ?
    Your "Kindergarten" work with these 109's, has convinced me to do the same thing with some 1/48 scale P-47's and the 1/48 scale Airfix P-40's that I have in the stash.
    It is truly amazing how the little details like this will transform an already good looking model into a fantastic looking model. The best part is no cash is needed, only time and effort.
    Pedro, @holzhamer
    I agree with you about these Tamiya Emil's being the nicest ones available. They're very easily built, have ample details, and the fit of the parts is spot on. Erik has demonstrated with a little effort, they can be brought up to even higher standards.
    Thank you for all the kind words guys, I appreciate them!
    Louis, I have to confess to being an "eyeball Mk1" guy, and I have no idea! I bought a handle with bits in it and I have used the smallest there is. I simply measured by holding it against the styrene, and as there was room to drill, I did just that. Some of the openings are too narrow, and has been opened by thinning the back with a drill and then cutting from the outside - I may have some pictures of that next week (have a few very long, very early days starting tomorrow as I have to get up at 4, and not home untill 18-19ish).
    I did use the largest drill in the handle for the intakes for the sparkplug cooling air, but that will most likely be documented when I get back - first one were drilled with a small drill, but that is too small and a lot of work afterwards with a blade
    Ill get back with a better picture or two next week.
    Marcus Vinicius Teixeira Borges said 3 years, 8 months ago:
    Getting better all the way Erik.
    Looking great, my friend @airbum!
    Great improvement, Erik.
    Great looking modifications, Erik (@airbum). Looking forward to your 1/32 109 Werkes. They take up more shelf space, but the parts are easier to see for ancient eyes like mine.
    I do appreciate the kind words gentlemen. another post will come soon, this time going into some more detail on AM exhausts and such. I'll be back with the uptate later this evening (at least it is evening here in Denmark) Stay tuned @lgardner, @holzhamer, @mvtb, @fiveten, @johnb and @gblair.
