Spiros (@fiveten), Michel (@michel-verschuere) and John (@JohnB), thank you for the kind words gentlemen. The 1:1 will probably take up a bit more space in the house than I have available. . . Now while we are waiting on the individual colors the cockpits get a bit of attention;
Office furniture
Time to get some bits and pieces into the office
The PE details do need a bit of feddling, as does the plastic.
The first chain will be bent if you do not trim the end. And to make room for it along the wall, a cut needs to be made
It is not really a problem, as the chain does go through the spar in real life (through holes, but that will be a bit difficult
You cannot just make the hole higher, as the chain will then interfere with the gearhousing.
Next I put the first trimwheel in place
Followed by the next chain. That one needs a back-plate, and I CA’ed it too close to the outside wall. Will adjust the next two ones.
Now, these trimwheels are both marked as “15”, but they are different!
The inner one needs to have the spike to enable no 2 chain to fit, and then the outer wheel plops in place. (the pictures with the no 2 chain above are without glue, so better fit came when glue was added)
This is getting a bit long – apologies! Hope you are still here. . . lets have a last picture of where I got to now;
Now, next they are about to depart the kindergarten, as some sort of decision has been made. One will most likely be a B-1 – and they were all the same color, so no real need to decide the excact plane yet. The other two will be Doras, and both will be Legion Condor, but nothing firm yet on wich two, probably a camo wing and light color fuselage and a all grey one – the swiss will come at a later date, but that will be the modelsvit kit as it has the correct fairings for the cowlguns
