Mig-23 MLA. 1/32 trumpeter (red-39)
Started by millo lucian · 44 · 9 years ago
    millo lucian said 9 years, 10 months ago:
    My new project is Trumpeter MiG 32 ml, with its many glaring defects corrected with the Aires resin - cockpit plus drive bays and inlet separator plates Zactomodels, very few pieces of kit Eduard exterior and lots of buildings zero!
    Bernd Müller said 9 years, 10 months ago:
    Good luck with your new project, Millo. This will be another stunner from you!
    Drawings scaled-up to 1:32nd from a russian book "MiG 32 ML P MLD" by S. Burdin, published in Minsk, 1994, Pages 21- 28. Also of great help were "MiG-23 fighter variants MF,ML", bilingual Czech/English, from 4+ publications and "MiG-23/27 Flogger. Soviet Swing-Wing Fighter/Strike Arcraft", by Yefim Gordon and Keith Dexter, published by Aerofax.
    The shape and length of the nose are wrong, as confirmed by placing the parts over 1:32 line drawings (the red lines represent the outline of the kit parts)
    Profile nose too sharp, had to be replaced. I looked for an alternative and found that another Trumpeter kit. The point is that the nose has a wrong profile for aircraft came. The nose cone MiG 29!
    On the left you can see the original MiG 23 con, shortened and MiG 29 a dry fit half the fuselage.
    Pinocchio nose had set. This is how it looked:
    Compare it to his new cone, the one modified from the MiG 29. It makes a huge difference
    We also took the opportunity to further strengthen the area, or by adding styrene ...
    The difference can de seen, thats a huge kit by the way
    reproduction cone
    riveting and engraving detail
    Cockpit all done, ready to be installed in the front half of the fuselage
    The gear bays were first painted with a gloss enamel, mixed to match the Russian colors. The wires were done with Vallejo Model Color and sealed with Future. Flat acrylic paint, a combination of 95% grey (60% black + 40% white) and brown 5% was gassed with the airbrush, and then wiped off. A finishing touch, the wash was a mixture of ocher and black pigments.
    wheel bay Aires
    George Williams said 9 years, 10 months ago:
    This is looking very good, Millo, I'll be following your progress with great interest.
    The cockpit canopy now follows the fuselage spine outline instead of bulging out. It took a lot of filing to achieve this and then the lower frame had to be reconstructed with white styrene.
