The seventh week on the Invader has the decals applied and the rest of the details being worked on. The decals were a mix of kit decals and the aftermarket Kits World decals. Both sets of decals worked very well except the stars and bars insignia’s. The kit version looked like the blue ink around the star was too thin of a layer. The Kits World decals were a lighter blue and slightly smaller. I ended up using a set from another aftermarket sheet of insignia’s that are colored correctly and accurately sized for 1/48 scale.
I then added weight to the nose. Each engine nacelle has two ounces of weight behind the engine and I added two more to the front of the nose. This was enough weight so the aircraft sits properly on the landing gear. The landing gear was assembled and installed. The kit comes with two styles of wheels. One set was just regular wheels and the second set has a flat side represented wheels with weight on them. I used the latter set. The canopies were then detailed, painted, and installed. I also modified the recognition lights on the underside of the fuselage by drilling them slightly and filling them with acrylic gel. These were then painted with Tamiya clear green, red, and yellow.
I still have to finish the weathering and final details to complete the aircraft. Next week I will have the final photos of this build and a preview of the next build.
All the details and photos from the start can be seen in the build log at: https://davidsscalemodels.com/build-log/1-48-a-26b-intruder-maggies-drawers/
