Join iModeler today.
Started preparations for the primer. Canopy masked.
Moving right along, John (@johnb). It looks like you plan to mask for the canopy frames after the primer. Don't forget to mask the nose glass and side windows. :o)
Excellent preparation so far, my friend @johnb! Wheels and props look also very nice!
@gblair, thank you, George. My plan is to paint the frames by hand after all paintwork is done. Masking the nose is my first priority @fiveten, thanks a lot, Spiros.
Nose cone and side windows masked as well, ready to get some primer on.
Masking looks great, my friend @johnb! Looking forward to the painting!
@fiveten, thank you, Spiros
Wheel bays filled with sponge pieces and the transparent parts covered with liquid masks.
Excellent so far, my friend @johnb! Great use of primer, enabling you to fix minor bugs not seen before.
Steady hand? I would not dare handpainting - but perhaps I have to one day. Great progress john.
Looking forward to the painting, John (@johnb). That upper seam is always the one that opens up for me. Easy to fix, just another round of glue, fill, sand, and check.
@airbum, thank you, Erik. I'm going to try, if not successful I can still use masks. @gblair, thanks, George. Correct, a bit of filling, sanding and all should be ready for the paint.
Cleaned the seam seen on the fuselage joint, should look fine after another round of primer.
That should fix the problem, John (@johnb). I can hear the airbrush and camo calling... :o)
