Wheeeeelp, been a while!
Been a busy few months (thanks to the holidays), so modelling time had been limited. More importantly, despite how much I love the Corsair, I just wasn't feeling this project. When my time to model had been reduced, spending it sanding a wing for the 5th time wasn't my ideal of fun and I lost my mojo heavily. Then I got the P-39 as something quicker to focus on so as such the hobby time went towards that.
It's nearly a new year, so will this project be revived? Well I'd like to, though after March things get very busy to me and a new model landed in my lap due to Santa which I'll start yet another build thread on.
So what's been going on with this project? Well let me go back to my notes and see where we left off.
Recap
Huh, honestly not a lot has changed.
Firstly a few little bits were done (that I thought I already posted) such as the undercarriage, obviously not needed right now but will be needed in the future. These used photoetch included with the Aires set, as always looking at the instructions iss more of a suggestion so high quality photos are the true guide.
The main issue is those wings. I have big regrets with those resin wheel bays, the detail is nice but as I mentioned before the detail isn't anything that wouldn't be able to be done with a bit of wire and the stock parts. The issue is that the wing is slightly wider now, which made attaching the folding wings harder.
1. Left wing attached and no major issues, save a gap where part of the wing was damaged.
Now the folding wings on the Tamiya 1/48 are probably the weakest link of the kit, the option to do it folded is very nice and appreciated however when unfolded getting them to join up nicely without gaps is troublesome, and now with the wheel well making the wings a tad thicker that's even harder.
1. Underside shows sanding work was needed to prevent a 'step' between the two wing halves, but nothing terrible. Rescribing will naturally be required. The left wing fits with far less issues. Note the radiators also have fairly big gaps.
The left wing generally went on without too much issue, but some filler, sanding and thus rescribing was required. The problem is that right wing. It has gone through the process of sanding and filling at least 5 times. Either a dent becomes apparent a few days later, or the wing gets damaged accidently via just holding it, causing a crack, or on my last attempt the wing cracked heavily when I was trying to rescribe the details which are all heavily lost on that wing. Normally a minor dent or some missing panel lines wouldn't bother me and can be somewhat hidden with some heavy weathering (that dent could just be solved with some aluminium paint), but considering the subject it needs to be near pristine as the subject is pristine
1. Right wing assembled, grey primer sprayed to show problem areas more clearly and for further sanding. Riveting has crept further down the fuselage but I wouldn't go furthe runtil the wings are done.
That's about when I bought the P-39. Since then I did some minor bits, such as riveting the tail. This took time of course, but was more enjoyable than going for the wing.
1. The big ol problem area
Since then the kit has been left to the side a bit, I was hoping to get more done now life calms down a bit but with a shiny new model to do instead... Its a hard sale. The major blocking point is that wing, as soon as that jigsaw piece falls into place then the rest of the plane will come together quite quickly after.
1. Lots of sanding, pieces were rescribed previously but a dent (due to gluing) was too noticable so needed fixing. This layer of filler hasn't been fully sanded down yet. The filler near the front was where a crack developed when attempting to rescribe.
You know what, after writing this out I'll give it another crack. The issue again is that fixing it is a slow process. Filler takes a day to dry, sanding it down reveals issues, so then you need to apply filler and sand again, rinse and repeat.
1. Bored with the wing, rescribing was started. This was taken on 10/12/12 so probably a couple days of 30 minute sessions.
On the subject of riveting because I've seen it mentioned before on other forums. 'The F4U wasn't riveted, why add it?'. Totally correct, the Corsair was spot-welded which doesn't produce as noticeable an effect and on a factory fresh aircraft its very hard to see. That being said I don't see anyone complain about the Tamiya 1/32 having recessed 'rivets' to show this, and I think my best work so far is the Corsair I did with this technique. Modelling is a case of realism versus 'realism'. Overexaggerating painting, especially weathering and damage, helps create a more 'real' looking model. Panel lines are too big to be in scale, but the model panel lines a kit has the more detailed it looks and so on. Either way, with a paintjob that will be monotone I felt riveting (as well as opening up that nose) will provide more interest.
As a side whilst I didn't photograph it, I did carve out a bit more of that nose so the engine fits properly. Removing it did result in some of the framework coming apart (not breaking, just coming out of the holes it was glued in) so repeating it for the camera seems like a bad idea! It would be far easier to attach that piece at the end once the painting is all done and dusted.
In the meantime, I'll post the new project in a few days as not to spam and I'll be going back and trying to fix that wing every so often to try and break the traffic jam it has caused on productivity.
A further point: I won't blame my tools but I don't really have ideal stuff for rescribing, currently I've found best success with a razorsaw. That being one of the issues is trying to rescribe over filler. Fundementally I might need to go ahead and get some better supplies so I can actually rescribe over the filler, so something a bit thicker and stronger than the tamiya putty, Mr dissolved putty, and sprue glue.
