Three Me 262s
Started by Michael Turner · 132 · 3 years ago · 1/48, Dragon, Hobby Boss, Me-262, Tamiya
    Michael Turner said 4 years, 10 months ago:
    For my club's annual "gunna build" competition I'm building three Me 262s.
    1. Dragon Me 262A-1a/U4
    2. Tamiya Me 262A-1a
    3. Hobby Boss Me 262A-1a/U3
    Initial impressions:
    • Some flash on parts
    • Some sink marks – particularly lower rear port fuselage half
    • Rubber tyres to be replaced with True Details wheel set
    • Detailed gun bay but gun cover panel fit is poor
    • Etched metal seatbelts included
    • Instrument panel needs to be painted
    • Requires lead weights in nose to prevent tail sitting
    • Fit of parts is OK, but port fuselage is a bit warped
    Tamiya Me 262A-1a
    • Kit includes detailed gun bay and alternative open/closed gun bay covers
    • No seatbelts included
    • Decals for instrument panel
    • Kit includes white metal nose gear bay to prevent tail sitting
    • Fit of parts looks to be very good
    • Kit is a mix of Me 232A-1a/U3 (interim recon version) and Me 262A-5 (projected production recon version)
    • Me 262A-1a/U3: some were armed with a single MK 108 canon in nose with projecting blast tube and this is included on fuselage parts
    • Me 262A-5: was to be armed with two MK 108 canon in lower nose gun ports are moulded on fuselage halves and instructions have you add the MK 108s
    • Camera ports under nose are solid and incorrect shape. These could be covers that were intended for the Me 262A-5
    • Kit has internal parts for rear fuselage and open access panel
    • Main compass
    • Radio boxes and mounting frame
    • Oxygen bottles and mounting frame
    • Basic camera bay detail
    Spiros Pendedekas said 4 years, 10 months ago:
    This will be very nice, three Me-262s in a row. Read your reports about the kits; found them very informative.
    All the best!
    Erik Gjørup said 4 years, 10 months ago:
    Bring them on - I'm tuned in @michaelt
    Progress so far:
    Dragon
    I built the BK-50 gun in the nose an test fitted the fuselage halves.
    I had to remove a fair bit of plastic from the gun magazine to get the nose halves to close together.
    I also added some lead mass to the nose to prevent tail-sitting.
    I glued the fuselage nose and spine back to the base of the fin. You can see the extent of the starboard fuselage twist in the pictures.
    I got the rest of the fuselage aligned glued but had to do a bit of "reshaping" of the port fin leading edge when I couldn't get the parts completely matched.
    There is a bit of work to do to smooth out the joins and fill a few sink marks.
    Pedro L. Rocha said 4 years, 10 months ago:
    Nice! I ‘m working around the Tamiya kit also (amongst other builds). I also have in the stash the Dragon (Trimaster) kit and it’s reissue under Revell label. Not a bad kit but Tamiya has the edge there. If you don’t mind I’ll be following your WIP adventures Michael ;-).
    Here’s a pic of my ongoing 262
    am building it for a GB also
    Tamiya
    I built the cockpit and added after-market seatbelts.
    The gun bay goes together beautifully, even if I built it out of order.
    I've glued the fuselage halves together and the fit was near perfect, although there are a couple of seams to fill.
    G'day Pedro,
    I'll be interested to see how yours goes together too.
    Are you droping the leading edge slats?
    That's good progress, Michael. Got the Dragon night figher version; looked great in the box, but I can foresee to have similar fit problems like yours.
    Hobby Boss
    Oddly, Hobby Boss provides tabs on both sides of the cockpit tub that slot into raised slots on the fuselage sides. These are unnecessary as the forward and aft bulkheads to which the tub is attached will suffice to keep it in place.
    I removed both tabs (easy) and slots (more difficult).
    As noted above, the kit includes gun ports either side of the nose that are not correct for the Me 262A-1a/U3, so I glued some plastic rod in the ports and then sanded and filled them.
    The Classic Publications book has a photo of the camera ports of the actual aircraft I'm modelling so I modified the parts and added clear acetate windows.
    I added after-market seatbelts to the seat.
    HB kit comes along nicely too, Michael. I also don't like these tab and slot connections.
    All the best!
    Hey Michael, yes I am.
    Using the long OOP set from Cutting Edge. It’s a good resin but the area where it goes makes it a very fiddly work. Got a bit bogged because of it, but will push forward to see it completed.
    Looking with interest at your HB kit. So far you’ve pointed several inaccuracies in it that I was not at all aware.
    George R Blair Jr said 4 years, 10 months ago:
    Building three 262's at once should fill your WW2 jet fighter requirement for a while, Michael. All are looking good. Cheers
    And this is number 4.
    It is the Dragon kit and was built back in 2005 (how long ago?!).
    I came 2nd in the "Open Aircraft - Medium (1/36 to 1/71) Enhanced" category at the Australian Model Expo (Melbourne, 2005). That is the only time any of my builds have placed.
    I've just re-read my build comments and will have to look out for those issues on this kit.
    (see http://www.members.optusnet.com.au/%7Egmturner/aircraft/me262a2/me262a2.htm)
    At least I haven't forgotten the nose weights this time.
    No4 is great, Michael. The camo turned out splendid!
