Workbench Ocupants.
Started by Allan J Withers · 144 · 2 years ago · 1/72, RAAF
    Spiros Pendedekas said 2 years, 11 months ago:
    The camo looks spectacular, my friend @kalamazoo!
    Allan J Withers said 2 years, 11 months ago:
    Thanks John, -------------
    Thanks Spiros, ---------------
    A few issues with the paint to sort out !
    Prince ----------- more lead in nose, will add a bit more, prop's ready for paint.
    The lead seems to be sufficient, Allan @kalamazoo
    Good progress on the spinners.
    Erik Gjørup said 2 years, 11 months ago:
    Nice progress on Vengeance and Prince - fine use of a topic to make more builds in one. I tend to loose track of some of mine in the outdoor season here on the other side of the globe.
    Nice progress, my friend @kalamazoo!
    Amazing how much weight some models need!
    Thanks John, a bit more lead added, -----------
    Thanks Erik, this seemed like a good way to keep track of my long term builds, I don't spend much time outdoors these days, ---------------
    Thanks Spiros, plastic engines don't weigh much, -------------------
    Prince ------------ has enough lead now, prop's are ready when the rest catches up !
    Steady progress, Allan @kalamazoo
    Thanks john, ---------------
    Progress will slow a bit while I try to finish some other models !
    Prince --------- some plastic added to nose and Plasto in low spots on nose and wing roots !
    Vengeance ------------ a touch up of the tan needed.
    Gannet ------------ glued the prop blades in, out of alignment, cut them off, will drill and pin them !
    Some serious work done, and ahead, Allan @kalamazoo
    Great work on the nose section.
    Amazing work on those challenging kits, my friend @kalamazoo!
    It is really amazing to see the way you transform "challenging" kits into masterpieces!
    Thanks for sharing all these nice updates - seems like there are lots going on at the @kalamazoo bench these days!
