Interior basics
More LqS to the crack in the hatch and some work on the IP and interior
The bits and pieces that got some attention
The figure is only used to “measure” the interior – I do not think he is going to be included in the build, but you never know.
To start with second and third (and final?) layer of LqS has been added to the front
I think the rest will be taken care of by paintfiller or perhaps a touch of thinned filler.
The instrument panel on these were rather basic, with speedometer in the center, the other center blanked off, and an open glove compartment in each side.
1. to be drilled and carved
1. Will recieve some thinner or extra thin glue to smooth things
2. Note the original thin edge here
I drilled out the openings, added evergreen, drilled and carved again and then an endplate. It will be smoothened by some extra thin glue/thinner later on when the Contacta has set.
The front end is very open and a huge support for the steering column is intruding.
I removed some material and has started to build a more realistic footwell in card. (I am thinking of one or two open windows and that will give an unobstructed view of the interior)
next up – well, I do not have a clue. It seems like “automotive” is not agroup that catches people, so perhaps just the finished car? Should you by accident have passed by, do feel free to leave a comment
