While I am waiting for the canopy mask to arrive in the mail, I decided I could get some work done on the underside of the plane. The color of choice here is Neutral Gray from Tamiya. I planned to apply the base color, then do some highlighting with white added to the base color, followed by some random darkened gray. In the photos I have of this plane, you really can't see much of the underside. I would expect the paint to be worn and a little splotchy, but probably not faded.
The base coat went on well, then I applied the lightened gray in a random pattern. I masked the ailerons using post-it-notes and applied the lightened color. For the darkened color, I wanted to try using an AK Stencil to apply a very random pattern. I haven't used a stencil before, but I like it. After that was done, the underside looked like a tiger with dark spots. I sprayed a very thin (basically a wash) coat over the entire underside to unify the colors.
Overall, I am only semi-happy with the results. I didn't have enough difference between the tones I was using, so when I applied the last unifying application of the base color it basically take away all of the contrast. I plan to put the plane aside for the rest of the day and decide tomorrow if I need to do some more work on the underside. There will still be a lot of work with artist oil colors, so I will need to allow for the later work to come. I painted one panel with a slightly darker gray to suggest a panel replacement. We'll see how it goes. When you look at the photos, they were taken under different lighting that make the colors look vastly different.
Everyone stay safe. Cheers.
