The hiatus was a little longer than I expected due to the fact we actually had a winter this year, complete with a pair of ice storms and a tad bit of that white stuff. Not normal at all for this part of the world. My shop is in the garage. It got cold enough out there that epoxy wouldn't come out of the bottle...
The resin cameras have been painted and installed. That was a bit of a waste of time, as I painted all that nice detail only to find you can't see any of it once the cameras are in place. But they do look better than empty space behind the clear ports, so it was worth it. I'm glad now I didn't spring for a resin cockpit. I'll join the fuselage halves later today.
Some old fashioned tube glue and a bunch of clothespins got rid of the warp in the wing. There is still no dihedral at all. As I mentioned before, fit to the fuselage is horrible. I found that part #24, a little wedge shaped piece on the lower wing just ahead of the formation lights was keeping the aft end from seating flush with the fuselage. The two cockpit bulkheads were doing the same thing. Some trimming and filing took care of that. Had to shim the right forward edge of the wing (behind the chin scoop) to eliminate a pretty serious step there. I'll be able to get the dihedral back, but there will be some pretty serious gaps that will need to be filled.
A request for help here. Does anyone happen to know the Testor's Model Master equivalents for the extra dark sea gray and sky that I'll need? I've found a dark sea gray and sky gray, but am not sure if those are the correct colors. And Erich, if you're still following this, where did you get your decals?
Will try to get some photos posted later.
