Arma Hobby 1/72 FM-2 Wildcat
Started by George R Blair Jr · 83 · 1 month ago · 1/72, Arma Hobby, FM-2 Wildcat
    Carl Smoot said 2 months ago:
    Congratulations on getting to the decaling stage George (@gblair). I imagine the small size of the aircraft really makes those curves have small radiuses, making it difficult to get anything but the very thinnest of decals down without some initial wrinkling. And those stencils, my oh my, those are tiny..
    George R Blair Jr said 2 months ago:
    Hi Carl (@clipper): I need to take a good look at the small decals after they are fully dry. The decals were a little thick, so I want to be sure the clear flat has a fighting chance to blend the decals into the finish. I don't want the small decals look like dots on the surface of the fuselage.
    Spiros Pendedekas said 2 months ago:
    Looks great with the decals applied, my friend @gblair!
    John vd Biggelaar said 2 months ago:
    The decals went on beautifully, George @gblair
    When applying Micro Sol on those wrinckled decals, do you just let the fluid do its work or you help them to get smooth with a Q-tip or similar.
    capt. R said 2 months ago:
    Decals look nice. Mabye try Tamiya liquid for decals? For me it works perfectly well.
    Thanks, Spiros (@fiveten), John (@johnb), and Bernard (@lis). It is always nice to be past the decals, since this is one of the last big hurdles before finishing the kit. In this case, I still have those two fuselage decals that need some persuasion. I have several stronger products that I use sometimes, with the strongest being Solvaset from Walthers. I had Solvaset actually dissolve the inks on the decal, and then you watch them run down the side of your model. The inks usually won't come off after that. Because these various chemicals are so strong, I test them on a decal you can't see, such as the national marking under the wing. I just test it in a small area, and I really try to avoid touching it, just in case the fluid loosens the inks. If that doesn't work, I may try to gently slice the area with a sharp knife and try the chemicals again, just like you would use on a bubble under the decal. If none of that works, I think I may just leave them alone. We are going over to the kids house today, but I hope to try doing all of that this afternoon. Thanks for stopping by.
    John Healy said 1 month, 4 weeks ago:
    Very nice, George.
    George R Blair Jr said 1 month, 4 weeks ago:
    Thanks, John (@j-healy). This has been a fun kit, even though I don't usually build 1/72.
    I spent the morning adding final parts and doing the detail painting on the plane, including the landing gear, pitot, antenna mast, and so on. I had to do some research because this plane had the usual position lights on the wings and tail, but it also had recognition lights on the belly, and some other lights on the spine that I think are formation lights. When everything was dry, the plane got a solid coat of Tamiya Clear Flat. I plan to let this dry overnight, then do some minor weathering, and call this one done. Cheers.
    Spiros Pendedekas said 1 month, 4 weeks ago:
    Almost done and looking awesome, my friend @gblair!
    Excellent job!
    John vd Biggelaar said 1 month, 4 weeks ago:
    Really nice progress, George @gblair
    Just a few bits before finishing this one.
    Thanks, Spiros (fiveten) and John (@johnb). Clear flat should be dry today, then some light weathering and it will be done. I still have my favorite task of the model to do: add the antenna wire.
    George R Blair Jr said 1 month, 3 weeks ago:
    The goal for today was to add the small parts, do the very last painting, then do some light weathering. I wanted to leave the under-wing rockets and drop tanks off until the weathering was complete. I haven't knocked anything off the plane yet, but I don't want to tempt fate. I started with the weathering using an oil wash mixed using light gray artist oils and enough Odorless Turpenoid to make a thin wash. I spread the wash over the wings, and then used a clean brush to massage the wash, removing a lot of the wash and creating some texture in the paint. I kept the brush moving in the direction of the airflow. When I was satisfied, I added some darker gray to the wash and repeated the process. Then I added some even darker gray, and repeated the process. I finally added some black to the wash and repeated the process. For the last 3 washes, I didn't spread the wash over everything, but in random, selected areas. I did the same process of 4 washes over the fuselage, but I tend to brush the wash in a vertical direction. After letting the washes dry for a couple of hours, I added dots of a very light off-white to selected panels, blended the oils with a dry brush, and then cleaned the edges with a brush damp with Turpenoid. Then I added a couple of fluid leaks around the engine cowling using a rust red, applied very lightly and again blended with a dry brush. I quit here because I wanted a subtle weathering. I have never been subtle or restrained, but hopefully I have come close. Oils dry slowly, but the Turpenoid accelerates the process a little. I plan to give it 24 hours to dry a little, then add the last parts, and call it done. Final pictures tomorrow. Cheers everyone.
    Eric Berg said 1 month, 3 weeks ago:
    Nice cat you have going here, George @gblair. Somehow I missed this until now. Finish line looks like it’s right up ahead. Arma Hobby kits are a real pleasure don’t you think?
    Hi, Eric (@eb801). I have several other Arma kits, but they are all 1/48. This was a fun build, even if it was full of parts I could barely see. Thanks for stopping in.
