Avia S-199, 1/48, HobbyCraft, Eduard, AML and scratchbuilt!
Started by Erik Gjørup · 92 · 1 year ago · 1/48, 109werke, avia, Czech, Haldværk, Messerschmitt, Mezek, s-199
    @fiveten, @johnb, @j-healy, @gblair, @lis, @eb801, @holzhamer and @lgardner, thanks gents
    Lis, I seem to have a stroke of luck with my legs. I almost always glue them as soon as possible, and so far only ever lost a tailgear! Louis is spot on with the first guess regarding the hole!
    Building bulges
    Been adding a thin layer LqS each day for a week
    to build up the bulges for the enginemounts
    also mounted the air intake
    and the airoutlet
    to enable the engine to breathe and keep the oil cool
    next up I hope to have all the LqS sanded and a few other bits done – tune in again!
    Looks great, Erik (@airbum). I always glue the struts on the plane as soon as I can. They come in handy when painting the plane. It is easy to mask and paint the gear later. I would vote for a port for the flare gun, also. Could you also build up the bulges using styrene pieces that you shape and then add to the plane?
    Looking great, my friend @airbum!
    Great work, Erik @airbum
    Thank you gents. @gblair, I actually used the styrene bits from the hobbycraft donorkit, added some evergreen to rough shape the lot, then LqS to get the final shape. Of course it would be possible to use some styrene runners that were thick enough, or cutting and sanding a piece of evergreen, but then I would miss the sniffing of glue (OK - windows open for that part)
    I cannot miss the sniffing part 🙂 my friends @airbum and @gblair!
    Fumes are part of the hobby sometimes, Erik (@airbum) and Spiros (@fiveten). Remember the smell from the old lacquer paints like Floquil? And the old lacquer thinner? The new stuff is much better. You still need to be careful. I use 4' x 8' sheets of insulation foam on my model railroad that I cut up with an electric hot knife to create the landforms for my model railroad. You should smell the fumes from that! I have a couple of fans going, and can still only use the knife for a couple of minutes.
    @fiveten, @johnb and @gblair, today I spent some time in the garden, but first a few quality moments at the bench!
    Let there be light
    I have started the process of making some nav-lights
    As usual it involves cutting the grey off and sanding a piece of clear to rough shape.
    It takes relatively little time compared to the end result, so well worth the effort in my book.
    Next I shall have to find the right shade for the exterior
    I think I have narrowed it down to Humbrol 165 or 167
    next up – could it be painted? Tune in and check!
    Nice wingtip lights, my friend @airbum! Looks like you settled to the correct gray!
    Nice job on the wingtip lights, Erik (@airbum). I like the gray brigade. After a while they all start looking the same.
    Such scratch build wingtip lights are a great addition, Erik @airbum
    So much gray, your chosen two are very close.
    Lights
    I know, I have been making these in numerous other builds.
    but I just show them again here
    First the bulb is drilled, then it is CA’ed to the wing. I let it dry overnight as I find the CA can let go if you sand too intensely too soon. Tape is there to avoid damage to the wing surface. Now the tricky part follows! How to mask them in a manner that is durable?
    This time I have used Tamiya clear, as I hope it will be easy to remove after painting the wings. Time will tell!
    Thanks for the explanation, Erik @airbum
    What is grid size you use at the final sanding to make it transparant again.
    Nice tutorial indeed, my friend @airbum!
    Thanks folks.
    I start with a coarse as you may have guessed, then 3200 for finetuning and finally polishing with a 6000 (the red one) stick that can hardly be called sanding 🙂 I also have a three surfaced polishing stick that I use on occasion, but today it was the 6000 @johnb.
