    Clear coat looks great, my friend @johnb! It will for sure give you flexibility when applying the top white.
    A layer of clear certainly can't hurt, and it makes it look like they just drove it out of the showroom. :o)
    Sebastijan Videc said 2 years, 3 months ago:
    Slowly recovering from my health issues, so not much progress, but I guess I can call the bottom of the wings done.
    Looking great, my friend @inflames!
    Erik Gjørup said 2 years, 3 months ago:
    @johnb, I think from the pictures the brush-painted solution looks best - at least on screen!
    @inflames, small progress is also progress - best of luck with the recovery of your health.
    @inflames, maybe a little, but it is nicely done. Health recovery is most important currently.
    @airbum, thanks, Erik. A little update in a mintue.
    Today was the moment of truth to see if the winter scheme would work well.
    After the clear coat dryed sufficiently, I applied the washable white randomly.
    Next I used a wide soft brush and applied water on a larger area to get the white a bit 'soaked'.
    After that, gently brushing a bit over the 'soaked' surface till the white vanishes at random locations.
    Current results are as shown on the next pictures, still a bit shiny because it did not fully dry yet.
    Comments on the results are welcome as always, whether good or bad.
    My thoughts are to apply a new very thin layer of the washable white and give it a very gentle rub.
    Looking great from here, my friend @johnb!
    Another thin layer seems a good idea!
    Eric Berg said 2 years, 3 months ago:
    Looking real good here John @johnb. I agree with Spiros. Just a smidge more white.
    Tom Cleaver said 2 years, 3 months ago:
    Actually, I'ma go with leaving the winter distemper as is. Makes the airplane look like it's put in some hard labor there on the eastern front gulag.
    @fiveten, thank you, Spiros. It turned out even better than I was hoping for. The washable white works great.
    @eb801, thanks, Eric. A very thin layer it will be.
    @tcinla, thanks a lot, Tom. The idea is to apply a very thin layer to smoothen the sharp demarcations of the current effects.
    After a second round of some winter white, a very light mist, and some rubbing, I do think the results are not that bad.
    Of course a bit of weathering needs to be done also at a later stage.
    My personal opinion is that this washable white is very nice to get a decent winter look and is quite easy to use, thanks for the advice George @gblair.
    The pictures below are taken in outdoor lighting.
    Looks wonderful, my friend @johnb! The washable white is a huge success!
    I think you can score this as a win, John (@johnb). Looks great. How controllable was the paint removal process? Did the paint come off easy, or did you have to work at it?
    Wings look great, Sebastijan (@inflames). The detailed panel lines and rivets will look great with the paint and weathering.
