@gblair, @fiveten, @johnb, @lis, @lgardner, @j-healy and @chinesegeorge, the month-long wait for parts are over, and I am finally ready to make some minor progress on this one.
blip . . . . please wait . . . . . blip
The wait is over!
The parts arrived, and work can restart!
1. kit parts to be used, but correct parts inside for my V14!
The eagle-eyed observer will see that it is the standard exhausts on the package! That is right, but inside the correct direct-exit panels are to be found, even though they supposedly are not to be used for the advertised plane on the front of the box.
Good for me, as I am now able to use them for this one, and still be able to make a hook-equipped Emil! Or Tony? Ok, carved away at the front of my patient 109 that has been through a lot so far
1. still need to remove plastic behind the holes, but the carving to make the panel flush is done
1. Only two parts taken from the AM kit - everything else can be used on another build!
Just some testfit for now – work on the other side will follow before committing to CA.
next up the exhaustpanels will be in, perhaps a windscreen and hood in place, then it is off to the painters for some primer
