It's been awhile since I last posted in here, so here are some updated pictures and more thoughts on this kit.
First, it is NOT as nice a bui;ld as I had previously thought. It looks great, detail is very nice inside and out. What I am running into, is a major problem with getting the canopy on. It does not fit, when posed open. Parts are too thick, and do NOT stack inside each other. It is a real shame, if I have to hide all the cockpit detail under a closed canopy. Therefore I am determined to pose it open. This will involve sanding down the bottoms of canopy sections to make them shorter, so they WILL stack...UGH!
Another issue, the bomb bay doors don't meet in the middle, and you will need to add about 10 mm plastic strip to fully close them as well. I am guessing this kit was designed to be displayed with every orifice opened up to show off...yet they screwed the pooch badley with the cockpit, where 90% of the detail is! Ugh again!
The decals are so-so, not terrible, but nothing to great either. The canopy masks belong in the trash. They don't stick well, and they don't fit any better. Use Eduard if you take on this project.
Overall, it's become a challenge to complete this baby, but it does look terrific, and I will win through in the end. Will I build another one? Maybe. Knowing what I know now, maybe.
I am working to get this kit done, for the Battle of Midway Group Build, over in "Groups", which BTW, you all should check out, because there are some really excellent models being put together by our fellow imodelers
Regards,
Freddie from LI
