Lockheed F-104 Starfighter: A Triple (Plus) Build
Started by George R Blair Jr · 113 · 5 hours ago · F-104, F-104G, Lockheed, Starfighter, Triple Build
    Spiros Pendedekas said 5 days, 19 hours ago:
    My friend @johnb: It took me several rounds of filling and sanding to achieve a relatively good result. At first round I used liquefied styrene, whIch I am familiar with, then normal plastic filler. I believe your attempt with your plastic filler will be successful if you persist. If the anomaly still persists, I would also recommend adding a droplet of cyanoacrylate glue on top of the already sanded filler and sand smooth.
    Eric Berg said 5 days, 11 hours ago:
    John@johnb: use CA glue like Spiros advised. Works very well on shallow sink marks. You may have to do several applications. It’s always something isn’t t?
    Carl Smoot said 5 days, 11 hours ago:
    The problem with liquefied styrene (unless applied in very small and thin layers) is that the cement portion is subject to extended cure time and will shrink a little. Black CA glue applied in small amounts and cured with accelerator, then sanded right away, and then examined if more is needed will provide a great surface and will allow detail restoration as needed.
    All this construction work is coming along great John (@johnb), Spiros (@fiveten).
    John vd Biggelaar said 4 days, 19 hours ago:
    @fiveten, @eb801, @clipper, thanks a lot for those valuable advices. Definitely something that I can use to get rid of those marks.
    John vd Biggelaar said 4 days, 6 hours ago:
    First time I used CA to fill those sink marks as advised. Thanks for that. First I applied a drop with a tooth stick.
    Next grinding and polishing till it looked smooth, but as you can see, a second round is required but it definitely looks promising.
    Also drilled an opening for the Vulcan cannon to make it look a bit more realistic.
    Carl Smoot said 4 days, 5 hours ago:
    The main thing about using CA is to sand it fairly soon after it has set. It gets very hard after 8 hours or so and is harder to sand, making it more likely that the surrounding plastic will be affected. Black CA is somewhat more forgiving and can be sanded more easily. Another trick I use is to hold the part at various angles close to a light source after sanding. This often reveals small spots that need additional work. If done properly, you can often get away with no rework required after applying the primer coat.
    Spiros Pendedekas said 3 days, 22 hours ago:
    Great job, my friend @johnb! Good that cyano glue worked on those nasty sink marks. Great trick to open the gun exit!
    John vd Biggelaar said 3 days, 20 hours ago:
    @clipper, I did sand the surface approximately fifteen minutes after applying the CA. That worked quite well. I need to check where I can get that black CA, never seen it here so far.
    @fiveten, thank you, Spiros.
    Eric Berg said 3 days, 5 hours ago:
    That CA glue worked well, didn't it, John, @Johnb? AMMO makes a black CA glue. Sure makes it easier to see what you're sanding.
    John vd Biggelaar said 2 days, 21 hours ago:
    @eb801, thank you, Eric. So far I'm pretty happy with the outcome, definitely an approach that I will use more often from now on. Going to have a look for the black one from AMMO, thanks for letting me know.
    John vd Biggelaar said 2 days, 6 hours ago:
    Wings and horizontal stabilizer are on.
    Spiros Pendedekas said 2 days, 5 hours ago:
    Looks excellent so far, my friend @johnb!
    Carl Smoot said 2 days, 4 hours ago:
    Very nice John (@johnb). Are you putting missiles or wing tip fuel tanks on this bird?
    Felix said 2 days, 3 hours ago:
    That F104 is coming along nicely, John @johnb! All that sanding takes time but it’s worth the effort!
    John Healy said 2 days, 3 hours ago:
    Nice clean work, John.
