Hello Erik, @airbum
Sorry for the late reply, and for not answering your questions sooner about the upcoming Mistel build(s). I have 4 of the Revell / Pro Modeler Ju-88 A4 kits in the stash. My understanding is that these are the older Dragon kit in a newer Pro Modeler box. I also have the actual Dragon Mistel S-2 kit that comes as a Ju-88 G-1 and a FW-190F-8, with both planes in the box.
Then I have a Paragon Designs resin conversion set that will allow me to use one of the Pro Modeller Ju-88 A4's and install a Bf-109 on top. This resin set has the Ju-88 fuselage extension plug and the necessary mounting struts for the parasite fighter.
I will most likely build two Mistel models. One will be with a Ju-88 G-10 / FW-190 and the other will have a Bf-109 on top, and will most likely be a Ju-88 A4 below. But I have enough parts to build up 3 different nose warheads, and some of the Mistel training planes retained the standard Ju-88 greenhouse nose. This Dragon kit has 3 seperate warhead nose cones in the box, and choices for a long projector nose cone or a short style.
So to be perfectly honest with you I am not exactly sure what I want to do at this very moment... but chances are I will build at least two of them when I start. I have a 1/48 scale Dragon Ju-188 under way now too... and it will have the BMW radial engines.
I have been really enjoying reading all of your various 109 builds... and I'm sorry to see how the paint has peeled up when you removed the masks on this one. I am sure that you have a method in mind to fix this small mishap. Please keep on posting these incredible works of art for us to drool over...
