Converting an F-2 to an F-1
Be warned – this is not for normal people!
In an attempt to get into the deep end, I have decided that I want to convert an F-2 to Werner Mölders F-1. The F-1 had retained the wingroots from the “Emil”, and some surgery is needed.
I had purchased one of Eduard’s Royal Class sets, and the first planche was for Mölders’ F-1 aircraft. Eduard included some photoetch to depict the top of the root-fairing, but this is not quite right, as the small bulge from the E needs to be there too.
I decided to slaughter an entire Emil-kit just for the roots! (An overtrees-kit only – they can be bought directly from eduard) The Emil and Friedrich compared;
1. Emil
2. Friedrich
3. Friedrich wings
1. The difference between width of the E and F root is quite pronounced
2. Emil tail
3. Friedrich tail
Now – the way forward?
As I see it one solution is to carve the Friedrich and add the Emil root, but as can be seen from the above that will make a large gap. Another solution is to keep the outermost part of the Friedrich’s fairing and slot the Emil fairing into the space carved out. Decisions decisions..
1. Emil slaughtered!
2. plasticsurgery on the Friedrich
1. Emil slotted into Friedrich root
1. Fortunately the kit contains resin exhausts to be added after painting!
Well as seen above I took the route of both! – steep learningcurve, lots of sweat, lots of dryfitting, lots of BEEP.. – aahhh the relaxation of kitbuilding.
If I ever take on this mission again - should choose to do so - it will probably be with the entire side cut off just aft of the cockpit – maybe.. (and the I can add a quickboost luggage room – niiice)
Anyway, that’s it for now – hope you can stop shaking your heads at some point in time. Please do not try this at home as insanity is likely to set in! – Oh well – come on now DO try, it is sooo much fun.
next up will be interior
