More resin
Having already used resin in the cockpit, a resin set is used for the wheels too
Now, in order not to create dust (they say resindust is harmful), I carefully used a new blade to cut a lot of the resin away to minimize the use of the saw.
And this is where the carpetmonster comes in!
One of the hubs decided to fly away, and a thorough search gave no result. A cup of coffe later it was found far away from the bench, having been molested by the monster (or me). And so a new center was made using a pair of plastic wheels. The difference is big, but barely noticeable on the finished product as they are on each side of the plane.
Next I feddled with the assembly and glued the windscreen and gun-throughs in place after some sanding and filing and sanding etc etc
1. gunthroughs fitted more snug
1. note lack of opening window
2. well - in my humble opinion it is an F1 in the picture - I may be wrong, but then early F-2 had Emil wingroots as well!
The windscreen had some major work, as the F1 did not have the opening in the left pane, and the rod in the glass had to be removed. The right lower panel needed removal of the flarepistolhole, as the F1 did not have this feature – I suppose it was in preparation for some pressurization? (usually uneven numbers are pressurized, even ones not so)
Well – slowly getting to understand this rather seldom version – fortunately one was flown by a famed pilot and a few pictures are to be found.
Next I think the special watercooler flaps may be presented – stay tuned (and comments on the guesswork above more than welcome)
