I put this on pre-order with Squadron, which resulted in a week's delay in getting it on release, due to Customs not letting Brandon get access to the kits for several days once they arrived. But it wasn't like I was twiddling my thumbs waiting impatiently, so all was well.
This kit is really impressive.
The level of detail regarding the surface detail, cockpit detail, engine detail, landing gear detail, is really staggering. If detail is your thing, this kit does to the Tamiya P-47 what Eduard did to the Tamiya P-51D. The kit doesn't make the Tamiya kit obsolete or anything, but it definitely steps up to first place for the detail.
This "basic kit" doesn't have a flaps-lowered option, though all control surfaces are separate. To me that's not a big deal, because outside of the Merlin P-51s, most World War II fighters don't sit on the ground with the flaps lowered. As Wayne Coleman from the 78th FG once told me, failing to raise the flaps once the airplane was on the ground would result in a 10-pound fine ($50, when a 2nd Lt's pay was $250 - enough to make one take notice).
One thing I noticed is that the prop is larger in diameter than the Tamiya prop. I haven't taken measurements yet, so I can't say who got it right, but I will do that with the next update.
The decals are the one failing. Mini-Art - like many others - can't seem to figure out the dimensions of US national insignia. And they are completely wrong about underwing insignias in the ETO being two different sizes. The personal markings for Schilling's airplane are worthwhile. Fortunately, there are lots of P-47D "bubbletop" aftermarket options still available at reasonable prices if you don't have a stash of them already. I'm going to use an Aeromaster sheet to do "Butch" from the 353rd FG with this one.
Fit of parts is superb. No filler needed on the fuselage, and the centerline fit was so good it only needed a light scrapedown. This means - as with most other modern CAD designs - that you have to get the mating surfaces absolutely right: nice and smooth.
This is also a kit that requires you to commit the revolutionary act of actually reading and following the instructions. The extensive instruction booklet is definitely not "somebody's opinion." There are a lot of small parts, and you definitely need to consult the sheet to find out not only what goes where but where to find it on the several sprues.
Overall I like this a lot and it will definitely not be the only one I do. It's pretty obvious from some of the "do not use" parts on the sprues that a razorback will be forthcoming.
(yes, I managed to break off the radio antenna mast; replacing it wasn't hard, but take that as a sign to be careful in assembly)
