Okay, it has been a while since I last posted on my Typhoon. As previously stated, I started this kit as a little side project to keep myself busy while I waited to finish my Hawker Hurricane project. As said project neared the finish line, I shelved the Typhoon and it remained shelved long after the Hurricane was complete. That is because after finishing the Hurricane project I was burnt out and lost my modeling mojo. This happens all the time, so I indulged in other things (flight simulation, bicycling, cat-napping, whiskey sipping, etc) until my mojo returned. Well, I am back in the game and am about to embark on another in depth project, but before I do, I figured I would finish this Typhoon off to dust off my modeling joints. First thing I did was to attach the KMC resin Tempest tail planes. Big mistake as the fit was absolutely atrocious! I have used many KMC products in the past (cockpits, wings, wheels, and other detail parts) and they were always an effortless drop in fit. I don't know what happened this time, but KMC really screwed the pooch with these tail planes. If I ever build this kit again, I am going to stick with the kit supplied tail planes. Next came the wheel bays and the usual debate, should I knock myself out over something that won't be seen once it is finished and glued to a base or should I just let it go. Well, as is grossly apparent, detailed wheel bays won out. What the hell, I am always looking to sharpen my scratch-building skills anyhow. Lastly came the radiator. Typhoons have that gigantic chin scoop which gives the aircraft a really aggressive look. I wanted to capture that look so, more scratch-building, filling, sanding, contouring, and shaping. I really love the end result. Far better than going with the kit item. A few more little tid-bits and my typhoon will be ready for paint. Have not decided on a paint scheme yet but something with full invasion stripes is a definite.
20 attached images. Click to enlarge.
1. Wings dry fitted. Fit is pretty darn good with just a minor gap here and there. Nothing I can't fix.
2. Fit of the windscreen was kind of poor and required careful filling, sanding, and contouring. Overall, everything turned out alright.
1. KMC Tempest tailplanes added. Totally horrible fit on both sides requiring a ton of filling, sanding, and contouring. All I can say is never again, brother.
1. Starting to look like a Hawker Typhoon.
1. Scratch-built wheel bays
1. Lattice created with a small triangular template and a sewing needle in a pinvise.
2. Stainless steel wire with a piece of photo-etch fret bracket.
3. Loads of small plastic strips cut to size to form the ribs. Lots of time, liquid cement, and swearing.
1. Forming the back corners was a real bitch but totally worth the effort.
2. Oval hole cut for the radiator flap actuator.
3. Filled in the holes for the kit rocket rails which are sub-par. I might have to scratch-build new rails. Thankfully, I have the Paragon rockets so that is at least half the battle.
1. Scratch-built oxygen bottles
2. KMC landing gear doors. I prefer these over the kit doors as they have the proper internal detail
3. Scratch-built gear door actuators and brackets
1. Everything fits pretty well in the starboard wheel bay.
1. Port gear bay looks pretty damned good also.
1. Rather than try to drill out the cannon barrel tips, I cut them off, drilled holes in the barrels and super glued in small pieces of metal tubing.
1. Oh yeeaah! Looks good. Thump Thump Thump Thump!!!!!!!
1. Kit radiator housing
2. KMC radiator housing
3. I figure I can combine the two of these into something more reasonable
1. Lots of cutting, gluing, sanding, shaping, and fitting, but I have myself a radiator.
1. Plastic strip all around.
2. Plastic strip braces.
3. Plastic strip fins.
4. Hollowed out center.
5. Photo-etch mesh.
1. Front end of a bomb half forms this cover
1. Radiator protrudes a little farther forward than it should in reality, but I'm going with it anyway.
1. After a bit of priming the results speak for themselves.
1. After hitting the tail planes with some primer, I'm happy to report all the filling, sanding, shaping , and contouring paid off.
