Decals done.
A note on this airplane and Bud Anderson's "Old Crow." Both were originally delivered in NMF from the factory, then - like the rest of the 357th FG in the summer of 1944 - given an overall camouflage of RAF Dark Green and RAF Medium Sea Grey. That fall, a lot of the camouflage paint came off; some left the upper surfaces, some (like these two) removed all of it. I asked Bud Anderson about this and he said that when the paint was removed, they did not stencil the airplanes "our ground crews knew where everything went." So, if you do a 357th airplane with that history (check photos), you don't need to do more than the fueling and grounding points. However, if you do an airplane delivered later, that wasn't painted at the unit (such as Kit Carson's P-51K), then the stencils are there. Again, research is 75% of a model.
While there are decal sheets out there that do this airplane (early Aeromaster, a SuperScale sheet, both only available on eBay - others overseas I'm not aware of) the Barracuda Studios sheet is most accurate (other than the nose checkers don't fit - I used the nose checkers from the Chattanooga Choo-Choo sheet). Because it was done fairly recently, after She Who Won't Be Named Here had copyrighted everything "Yeager" she could, and enforced the copyrights, the name is done in multiple parts, with the instructions formally telling you how to do "an interesting fictional aircraft that can be modified." (Roy Sutherland having a very good sense of humor when dealing with the humorless)
