Last night I made some more progress with the Zero builds. Work commenced on the wings.
Hasegawa uses a small plug insert in this location, where the older Tamiya kit does not. From what I have read online, if any filler is needed, most likely this is where it will be used.
I decided that I would try to eliminate the problem and glued the insert in place now before I went any further. I thought it would be easier to work the gaps while I could get to both sides. Here are the end results. It's not perfect, but I'm happy with the results.
Before the air intake was glued in position, I used a small round file and thinned out the lip of the opening to make it look more realistic. There was a tiny amount of flash present in this location, so it had to be addressed anyhow.
I also finished the assembly work on the cockpits. Here the 3 Hasegawa offices are done.
I placed all 5 of them together for this next picture. The older Tamiya kit parts are lighter colored plastic and are on the right in the next picture.
The fuselage assemblies were also glued together. Here I have them alternating back and forth with a Tamiya fuselage placed in between each Hasegawa part.
The lower wings were prepped for final assembly. I filed and sanded away the sprue attachment points. Here all 5 wings are shown. You can see the differences between the Hasegawa plastic and the Tamiya which is lighter. You can also see the round wing tips of the Model 22 version, and how they differ from the Model 32 clipped wing tips.
The surface details are fairly close, even thought the Tamiya kit is much older. The Hasegawa kit has the advantage here, but please keep in mind it's also a lot newer. Tamiya was cutting edge when they released this Zero model back in the 1970's. Tamiya has the inner gear door actuators molded integral as a part of the lower wing, while Hasegawa includes them as a separate part. They look better as a separate part to me.
Here are the A6M-3 model 32 wings sitting next to each other. Tamiya is shown above the Hasegawa kit part.
Then I removed the engine cowlings and placed them next to each other. They look very similar in appearance, but the Hasegawa kit parts have the cooling flaps molded as an integral part. The air intake is more defined in the Hasegawa kit part in my opinion.
Finally, I glued the drop tanks together. The Hasegawa kit parts are shown on the right and are molded in a darker gray colored plastic. Tamiya tanks are on the left. These look very similar too, but Tamiya has a small vent pipe included that Hasegawa omitted. It's near the tail end of the drop tank. The Hasegawa part has a better detailed fuel filler cap.
Both look very respectable.
