I've been working on this for the past two days - it arrived on Wednesday and after one look in the box I was on my way.
This is definitely not the 1/32 kit. The fuselage and wing parts are molded type-specific, so there's not any of that extra fitting and fiddling. Everything goes together easily.
The kit is definitely from Eduard (down to having Tempest V trees from that kit), much similar to the Tempest V, except the fit is overall better in detail, and the wing doesn't have that split between upper/lower down the middle of the flap. As you can see from the photos, it came together with no putty or filler needed anywhere.
I used the Eduard p-e instrument panel from a Tempest V kit - the kit doesn't have that on its own. I also used the Barracudacast resin seat I had for a Tempest V just because it made things easier, though it's not necessary.
I didn't use the resin engine, which is quite nice, but I'm thinking I will use it on my next Airfix Sea Fury.
Overall, this is a definite winner.
