You know I totally forgot to complete this WIP on the Dinah. With so much going on I just realized I had left off installing the engines. This session I will get to the point that it is ready for paint. I had finished off the props, painted them Red Brown. And a temporary fit on the engines. Next painted the IP coaming Flat Black. Then install the antenna. Next to start attaching the clear glazings. Starting with the lower windows under the air frame. What I really like about the recent Tam kits, (well not that recent) how clear the windows are. And even better they fit! With out gaps, no blending. Especially on a multi panel clear canopies such as this Dinah. Most of the prior builds were fighters, single engine variety, with just a canopy and a windscreen. The clear parts for this went on as they should. The only thing is masking all that glass, the most dreaded part of the build even on simple jet canopies. Very little room for error. So out comes the long arduous step of applying the Eduards canopy masks. So starting with the bottom windows, I work my way to the side windows and then with the rear compartment set of glass. The process seems like it takes all day, but to save my sanity, I apply as much as I can in 20-30 minutes, put it aside to do something else and come back to work another 20-30 minutes until I am done. Next time, go over the air frame, and then start the painting process. More to follow. Thanks for viewing.
23 attached images. Click to enlarge.
