Trumpeter Vickers Wellington Mk.Ic 1/72
Started by John vd Biggelaar · 50 · 2 years ago
    Last Christmas, my daughter, sorry Santa Claus, surprised me with a very nice Vickers Wellington Mk.Ic from Trumpeter in 1/72 scale.
    The nicest thing about unpacking these presents is that you have to unpack twice, first the gift paper and secondly the box to get to the plastic. The plastic looks very nice, pretty detailed although the geodetic structure is a bit too visible. Maybe it can be toned down with polishing.
    Transparant parts and decals do look promising as well.
    Schemes to choose from are the No.149 squadron or the No.301 Polish squadron. My daughter has always the tendency to seek something in the codings of my models which refer to something in Formula 1. For this reason I will build the No.301 squadron aircraft, GRoH (where GR refers to George Russell). Provided scheme layout is nicely colored and the back/white instructions are very clear.
    It will be the first 1/72 scale model since I returned to this hobby, so let's see if my eyes and coordination is still sufficient to get this done. Help to make this build look perfect is done with the aid of some aftermarket sets, an PE set from Eduard and a masking set from Montex.
    It might be a longer build because of the smaller than my known 1/48 parts, and the number of parts is clearly more than a 1/48 single engine aircraft.
    Eric Berg said 3 years ago:
    @johnb - what a thoughful daughter you have. Did somebody put a word in her ear? This will be an interesting build especially to see how this kit compares to the old Revell Wellington.
    Louis Gardner said 3 years ago:
    John, @johnb
    This looks like a wonderful gift you received. I have been tempted to get one of these but in 1/48 scale. My eyes are not what they once were, so I quit building 1/72 anymore. I will definitely be looking for updates. Thanks !
    Spiros Pendedekas said 2 years, 12 months ago:
    What a wonderful entry, my friend @johnb! Nothing better than eceiving such a gift from your daughter! Looking forward to your progress!
    John vd Biggelaar said 2 years, 12 months ago:
    @eb801, @lgardner, @fiveten, some hints were indeed given to my daughter. Nevertheless it was great that she wanted to suprise me with this gift. Seems like I'm not a bad dad after all 😉
    Just had a better look at the PE set from Eduard. Three nicely detailed frames with a lot of PE parts of which one contains pre-painted parts for the instrumentation. Also the provided instructions are nicely detailed.
    Soon a start will be made on this classic aircraft.
    Those PEs look wonderful, my friend @johnb!
    Will enhance a lot your Wellington looks!
    First steps made on this iconic bomber from the RAF at the beginning of WWII.
    It has been a long time that I worked on a 1/72 scale aircraft.
    The parts seem much smaller than I remembered when I built this scale while I was a kid.
    Started with the pilot seat which gets a replacement of PE parts.
    The part below the plastic seat had to be removed and used for the PE seat according the instructions.
    A sharp blade was an absolute requirement.
    Although small, the PE parts from Eduard were quite easy to bend into the correct shape.
    Spiros Pendedekas said 2 years, 11 months ago:
    Great step, my friend @johnb! The PE seat looks waaaaay better than the kit-supplied one!
    Tom Cleaver said 2 years, 11 months ago:
    Have fun with this.
    Looking at your photos and then looking in my Airfix Wellington kit, I think Airfix wins the battle of the surface detail (much more restrained). I'm awaiting some items from Eduard for detail. I never thought I would ever see the Wellington II (Merlin-powered) done as an injection kit.
    @fiveten, @tcinla, thanks a lot my friends. Surface detail of this Trumpeter does indeed look a bit overdone. I might give it a try to reduce it by grinding.
    Work on the pilot seat done together with the Eduard PE provided.
    Not easy to get used to 1/72 I have to say. The seat is finished except for the side arms.
    It does however already consist of ten parts, Two plastic and the rest PE.
    No! Don't try anything - you'll wreck it! It's just one of those things you have to put up with and your next Wellington will be in a nice red box. 🙂
    Eric Berg said 2 years, 11 months ago:
    @johnb - I agree with TC. Leave it alone. Don't mess with it. Once you attach the side arms it will visually tone down.
    You're off and running now!
    Great job on that seat, my friend @johnb!
    Erik Gjørup said 2 years, 11 months ago:
    I fully agree with you @johnb. Those overdone surfacedetails on the exterior need to be dealt with. Perhaps a few rounds of primer and sanding will do the trick. Looking forward to your decision.
    @tcinla, @eb801, @fiveten, @airbum, thanks a lot for the feedback. Although I'm a bit in doubt what to do. Leaving it as is, is ofcourse the most safe approach, but the overdone surface detail on the wings and fuselage might be too distractive once the aircraft is finished. I think I will do some trials and see if I can find a good way to reduce those details.
    In the meantime I finished the pilot'sseat. Since the seat is balc painted leather, I tried to give it a bit of worn effect by adding some brown streaks which should represent the original leather color. Armrests were metal so some metal scratches are added as well.
