Wings!
With the fuselage assembled it is time to add wings
For an Eduard 109 it is impossible to glue the lower wing in place first, so I dryfitted this one to check.
That is all very well. The reason for fitting the lower wing first is to be able to adjust the upper panels so that the root will fit without filler. This is done by adjusting the outer edges, but it actually seemed like the AMG kit fits like a glove!
When trimming the upper panel, there is an attachment that is within the curved area, and that needs some sort of round sander.
On the leading edges there are some tabs that should not be mistaken for attachment points that needs sanding. They are for the slats if you want them open.
To glue the skin in place you need to add glue BEHIND the edge, as it fits on top of the lower skin.
And with all taped up just a single peg is needed to hold everything until the glue is cured
next up some thoughts on where to set the ailerons, elevators and stuff. Comments are most welcome, and appreciated
