Thank you, guys!
@gkittinger Greg, please note – Amodel is producing a prototype version of Yak-130, and there may be differences between late production versions. Zvezda has new Yak-130 kit in 1/72 scale also.
I've finished painting the camouflage, along with the small details like antennas. After that a gloss coat was applied. It's not visible on the photos, but unfortunately I need to re-paint intakes, because masking tape has left glue marks. Camo colors were mixed using Hataka lacquer paints. Light Blue is 1/2 mix of C284/C101 and dark blue color is 1/4 mix of C101/C255. These colors are hard ones. Especially the darker blue looks so different on different photos, so it's rather guessing, than an "accurate" representation. Also, radio transparent parts where painted using XF-24 color, rather than what was given in the instruction.
For wheel discs it was easy – Tamiya XF-5 is enough green for this.
There is a quest with landing gear legs color and insides of a wheel bay doors. Again, instruction gives some strange advises here, so I've done some research. Look on this photo:
1. different color of a landing gear leg part
Inside color of the doors is white, as for entire wheel bay. But looks like legs has different parts painted in different colors. It's also could be seen on this photo:
The "horizontal" arm on both nose and main legs are painted in some metallic grey color, so I've chosen XF-23 as a base color and a mix of dark grey and metallic black for that darker parts.
