Thanks everyone for the kind words.
Stephen, @stephen-w-towle
You made me smile with the Keebler elves comment. Sometimes it seems to work and I get a lot done, while other times it takes me way too long.
Walt, @luftwaffe-birdman
I am also very impressed by the details they gave us. This kit has a lot going for it. It will get even better once I complete the seats harnesses and the seats get installed. This is the plane I will be building. It is coded "G9+FK"
I liked this on the best because of the way the underside of the wings were painted. One wing is Black while the other side is RLM 76. The top side will be painted in overall RLM 75 with 76 squiggles over the top of that.
Last night I managed to complete the tail assembly and install it on the fuselage. I also have the wings constructed. I will try to get pictures posted tonight...
Michael, @faraomike
Thanks buddy , please stay tuned as I hope to post another update tonight. Spiros' plane is ahead of mine with the build.
George, @gblair
Thanks for the compliments. I usually build models at night, (or when the weather is bad), as I try to spend most of the day with the misses, doing little things together around the house, or working out in the shop with her truck restoration. I too am impressed with the cockpit, and it should look even better once the seats are completed and installed. They provided decals for all of the instruments, and they worked very nicely. I wouldn't have wanted to paint all these gauges... This is definitely going to take up some room in the display case... I hope to park some 109's and 190's under the wings. Maybe one on each side...
Spiros, @fiveten
Your big Uhu is spectacular, and I like how you secured the weight in the nacelles. I'll bet that cost you some ice cream for QC1 and QC2, since you used some of their modeling clay !
Greg, @gkittinger
I do hope that you bring out your Uhu as well. I always like to read your build journals. I have picked up a set of brass radar antennae for this one. It will be my first try using these. I picked up a couple of sets for various Luftwaffe planes made by Master Brass.
Eric, @eb801
This is the first Uhu I have built since I was a teenager. Back then I built a much smaller 1/72 kit, and it was made by Revell. I have two of the 1/48 scale Tamiya kits in the stash, and will likely drag them out soon. I need to figure out which forum group to add them to... either the Night Fighter group as this one is, or do I go with our upcoming Luftwaffe group build, that is scheduled to start on May 1st.
I have decided to drop the flaps on this on, even though I have only found a few pictures of this being done on the real aircraft. I suspect the flaps were "supposed" to be raised by the pilot before shutting it down.
I wanted to be able to display the inner wing details... They have provided us with an exposed / open wing structure as an option. I will explain this and show the pictures later on tonight if things go as planned.
Spiros, @fiveten
Your build has progressed much more than I remembered... and it looks very nice (as usual). ๐
