Back to the bench for a little more work. I decided to add a few details that are missing from the kit (and there are quite a few of them!), so off to the junkbox I went. My Gooney had a rather prominent red rotating beacon on the fin, so I found a piece of clear red sprue from an old car kit and fabricated one. Slotted it with a small round file to fit the fin, then polished it with s fine sanding stick. I'll use the same sprue for the rotating beacon that will be on the belly. The wing landing lights were the headlights from the same car kit. They just happened to be the right size.
The exhaust stacks were drilled out, but they were missing the ram air tubes for the heaters. These were made from a piece of 1/16 brass tubing bent and cut to shape.
The DC-3 is a good size model in 1/48, so the main colors were all shot from rattle cans. The original scheme was the USAF white over bare metal. The white is gloss Krylon Colormaster, while the silver is Rustoleum 2X Metallic Aluminum. Both have primer already mixed it, so a couple of light coats was all it took to cover the green plastic.
The striping was the difficult part of the paint job. The red and yellow stripes along the windows are Testor's insignia red and yellow. The pinstriping had me stumped for a while, because I didn't want to try to paint them, and cutting decal stock that thin would have taxed my already frazzled nerves. The solution came from a trip to Michael's for something else.
This is self adhesive striping tape for RC models that comes in various widths from 1/2" to 1/64". It's very similar to automotive pinstriping tape. I've used it before and it was the perfect solution to my dilemma. Once I had the tape applied and well pressed down, I sealed it with a coat of future.
Last shot is of the model as it is today. I'm waiting for decals for the N-numbers to arrive (thanks Frank!) as no one seems to make letter and number decal sheets anymore and all the ones I have are really old and missing the numbers I need. Props are painted as is the landing gear. The engine cowls and control surface gaps were all picked out with Testor's CreateFX black acrylic wash. Once I have the decals on, I'll do the clear coats and weathering, then final assembly. I'm still debating whether to add all the various antennas the airplane was festooned with, as they have a tendency to get knocked off every time the the airplane gets moved or dusted...
